Engine diagnostic
  • rexthecat
11 years 8 months ago #140538 by rexthecat
Engine diagnostic was created by rexthecat
Can anyone reconmend a garage that could have a go at tracking down a running problem? Had a prob for ages, looses power when at operating temp, like its getting too hot only it's not. Not been able to get anyone to figure it so far anywhere. Suzuki won't touch it as it has mods. I'm in london but dont mind traveling a bit. Any help much appreciated as getting desperate to crack it. Been dealing with it by keeping it cool with electric fan but mud causes problems and thats a bit crap for an off roader!
Cheers
  • markyp2000
11 years 8 months ago #140542 by markyp2000
Replied by markyp2000 on topic Engine diagnostic
What work has been carried out so far also what engine does it have single or twin cam
  • Licksan
11 years 8 months ago #140543 by Licksan
Replied by Licksan on topic Engine diagnostic
These guys are good and meticulous at tracking down and sorting running problems and other faults but it's a fair drive from you!
www.autofaultfinder.com
  • rexthecat
11 years 8 months ago #140548 by rexthecat
Replied by rexthecat on topic Engine diagnostic
Cheers, so far replaced maf and cam sensors, new rad and thermostat. No codes come up, local garage couldn't figure it not the guy who's done most the work on it. Passed the mot no emissions prob. Any ideas appreciated.
Cheers
  • Licksan
11 years 8 months ago - 11 years 8 months ago #140551 by Licksan
Thinking about your fault it could well be the crank position sensor. Mine used to start loosing power and misfiring when warm but wasn't overheating. It didn't throw a permantant MIL but the light flickered when it was running irratically. The day I tried to datalog it it behaved itself! I changed the crank position sensor and the problem went away.
You can test it by tipping cold water on the sensor housing when it starts playing up. It's located behind the alternator on the M13A motor. The sensor breaks down when hot and gives the ECU false readings which causes power loss and misfire. If it then runs ok for a bit you can be pretty sure it's at fault. Well worth a try.
Last edit: 11 years 8 months ago by Licksan.
Time to create page: 0.089 seconds
