Panhard Rod Manual Extention
  • irishpaddy
12 Mar 2015 13:27 #140449 by irishpaddy
Panhard Rod Manual Extention was created by irishpaddy
I'm after a 3" suspension lift along with a 2" Body lift
Can any one tell me what how much i need to extend the current/standard Panhard Rods.
  • idiotmobil
12 Mar 2015 19:04 #140471 by idiotmobil
Replied by idiotmobil on topic Panhard Rod Manual Extention
You need to use The Pythagorean Theorem to work it out I done it to mine and it was some thing stupid like 3/4 of a inch, you need to use this theorem by measuring the existing lengths then add in the 3" lift to work out the new panhard length
  • idiotmobil
12 Mar 2015 19:06 #140472 by idiotmobil
www.calculatorsoup.com/calculators/geome.../triangles-right.php
just had a quick look and this would make it a lot easyer
  • idiotmobil
12 Mar 2015 19:08 - 12 Mar 2015 19:13 #140474 by idiotmobil
or if you wanted look through all the post ive ever done and some were in there is the size for panhards for a 3" lift
they were made on 11th of april 2014 so mite help to find the post around this date
Last edit: 12 Mar 2015 19:13 by idiotmobil.
12 Mar 2015 22:15 #140499 by kirkynut
The standard Panhard rods are weak, so just bug adjustable ones from Jimnybits.co.uk and adjust them till the axle is centre. For what they cost I imagine it's not worth making any.
  • idiotmobil
12 Mar 2015 22:33 #140501 by idiotmobil
Made mine for £30 save loads and why do they need to be adjustable if the lifts never going to change. In sure it was 21 mm longer on rear and 17 mm on front and made mine from 25 mm 2 mm walled cds. I had some slid in a hole and a scaffold bar over it and was jumping up and down on it about 6 foot away and couldn't bend it. Bent standered one in my hands lol
Time to create page: 0.098 seconds
