Valve replacement
  • mickt
11 years 8 months ago #140255 by mickt
Valve replacement was created by mickt
I am about to rebuild the head off my G13BB engine. Removing the valve springs was easy using a socket and a hammer to remove the collets. Replacing them is a bit more challenging. I have about 4 sets of valve spring compressors that were designed for the old school overhead valves. The valves on overhead cams are a bit more challenging and being so small, tightly packed and angled on the Jimny means my old tools will not do the job. Can anybody recommend or show me which of the many styles they have found best to use on the Jimny. I have used a home made extension piece before on a Jag engine but because of the angle and depth in the head of this that will be a if not impossible but a right old struggle, so any advice will be appreciated. Photos would help by the way!
  • John_S_RAA
11 years 8 months ago #140266 by John_S_RAA
Replied by John_S_RAA on topic Valve replacement
OK i did my head some years ago. Used a conventional type valve spring compressor with a spacer which I turned up on a lathe. The spacer diameter was just under the valve diameter and from memory about 20 to 30mm in length. It had a small spigot on it which fitted into the valve spring compressor so stayed central to compressor. Was not easy but I did it and have done some 50 000 miles since. Sorry no photos and the spacer is located in my shed.........somewhere.
  • mickt
11 years 8 months ago #140302 by mickt
Replied by mickt on topic Valve replacement
I am going to do that but it makes a fiddly job more fiddly. Especially because of the angle of the valves in the head. I would rather a purpose made item.
  • mickt
11 years 8 months ago #140397 by mickt
So having ordered a compressor that should do the job I decided to make an adaptor so that I can use a old school compressor.
  • mickt
11 years 7 months ago - 11 years 7 months ago #140957 by mickt
Got around to lapping the valves in and refitting the valves, seals and springs. A bit fiddly due tight clearances and angle of valves plus the "new" valve compressor is big and bulky and heavy making it always wanting to lean over to one side canting the springs over making it difficult to get the retainers in. hence the photo of the tweezers, long bladed screwdriver and everymans'
favourite helper! Next is to finish rebuilding the head with the rockers and the cam.
Last edit: 11 years 7 months ago by mickt. Reason: Further info added.
