Viscous Fan Clutch problem
11 years 8 months ago #140228
by safari
if u worry u die if u dont worry u still die so why worry
Viscous Fan Clutch problem was created by safari
hi have a problem with the Viscous Fan Clutch it is making a loude noise like loose bearings inside .has anybody change it or fitted something of another car cause cant find to buy one
11 years 8 months ago #140229
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Viscous Fan Clutch problem
I have some
Grey pick up Jimny
11 years 8 months ago #140248
by j999pre
Grey pick up Jimny
Could it be loose bolts or a bad water pump?
Grey pick up Jimny
11 years 8 months ago #140297
by safari
Replied by safari on topic Viscous Fan Clutch problem
hi no i have new waterpump the problem is the clutch it has something from the inside which is making the noise. i am waiting for an answer from a local dealer if he does not have i msg u and how much for it plsj999pre wrote: Could it be loose bolts or a bad water pump?
Time to create page: 0.087 seconds
