High engine revs
  • Basketcase
11 years 8 months ago #140136 by Basketcase
High engine revs was created by Basketcase
Not had the Jimny running for a few months while I fitted the winch to it now when I start it the reva won't stay below 2250, if you dab the throttle they drop to 1500 the. Go straight back up to 2250, I can't see any air leaks anywhere where air may be getting in. Any ideas?
  • Jabberwocky
11 years 8 months ago #140167 by Jabberwocky
Replied by Jabberwocky on topic High engine revs
I had that problem with my Jimny after it had sat on the driveway for an extended time.
It turned out if was the idle control valve which had sized up. I cured it by taking the throttle body off first and then the valve off of the throttle body. A good clean up and the valve was turning again like new. totally cured the problem for me B)
  • Basketcase
11 years 8 months ago #140169 by Basketcase
Replied by Basketcase on topic High engine revs
Thought it could be that but wanted some other opinions and as to where it is and how to get it off/clean it, cheers
11 years 8 months ago #140196 by kirkynut
Replied by kirkynut on topic High engine revs
I wonder if just using it regularly will help it sort itself out?
  • Basketcase
11 years 8 months ago #140198 by Basketcase
It's still got 1/4 tank of fuel in it since about October would that cause high revs?
11 years 8 months ago #140226 by kirkynut
Basketcase wrote: It's still got 1/4 tank of fuel in it since about October would that cause high revs?
No, it would cause misfires or lumpiness if anything. Fill it up with fresh to dilute the old stuff and after a few tank fulls (not long in a Jimny) it will mostly have gone.
