Oil filter screw m16a engine
  • Longman
11 years 8 months ago #140004 by Longman
Oil filter screw m16a engine was created by Longman
I have taken the oil filter housing off my m16a liana engine and there is already a screw thread there that the liana oil filter fits on is the jimny filter the same or do I still need to change the screw thread
  • Riceye46
11 years 8 months ago #140006 by Riceye46
Replied by Riceye46 on topic Oil filter screw m16a engine
hi longman iam sure its the same as I have done oil and filter last week and I have the same engine sent up as u and I got a oil filter of the reg number and it fitted prefect they did have a choice of sizes tho a fat one and a more thinner one but I think as long as the rubber seal makes a tight fit it don't matter as I tryed both and both fitted hope this helps cheers Chris
I have part numbers for both filters if that's an help to u
11 years 8 months ago #140009 by j999pre
The 3 I've done all needed a screw fitting after the 90 degree liana filter head was removed.
Grey pick up Jimny
The following user(s) said Thank You: Longman
  • Longman
11 years 8 months ago #140012 by Longman
Replied by Longman on topic Oil filter screw m16a engine
So there was no thread at all there when you took the old housing off
11 years 8 months ago #140013 by j999pre
Only an internal thread. I then used a new Suzuki Jimny oil screw from Suzuki. This screws in leaving 20mm sticking out for the oil filter to screw on to.
Grey pick up Jimny
  • Riceye46
11 years 8 months ago #140015 by Riceye46
Sorry total miss read your first post yes you need the jimny oil screw then the filter just screws on
Time to create page: 0.096 seconds
