temp gauge
  • Daniel30
04 Mar 2015 11:30 #139817 by Daniel30
temp gauge was created by Daniel30
Got an outside temperature gauge to fit if I put the sensor in the engine bay along by the battery or something Will it give a good reading or will the heat from the engine affect it?
Cheers
  • markyp2000
04 Mar 2015 16:34 #139835 by markyp2000
Replied by markyp2000 on topic temp gauge
Heat would affect it why not wire it up just under the trim at the lower part of the screen
  • Grego
04 Mar 2015 16:46 #139837 by Grego
Replied by Grego on topic temp gauge
I would put it underneath where the airflow can get to it, away from any sunlight to get an accurate reading , anywhere near the bay can also give a false reading by the sun hitting the bonnet, wrap it around the arb or somewhere in the wheel arch?, its a sealed sensor so should be ok exposed to the elements
  • Grego
04 Mar 2015 16:49 #139838 by Grego
P.s., where did you get it from.... something i miss not having in the Jim, suprised myself how much I look for it
  • Daniel30
04 Mar 2015 17:00 - 04 Mar 2015 17:05 #139840 by Daniel30
Replied by Daniel30 on topic temp gauge
Grego, I Got it off ebay from a link on this forum but can't remember who I'll find out the item number, the other person done a nice install in the wing mirror bit technical for me though ;)
Markyp2000 do you mean outside - just under the windscreen?
Cheers
Last edit: 04 Mar 2015 17:05 by Daniel30. Reason: me
  • Daniel30
04 Mar 2015 17:04 #139841 by Daniel30
Item 261536268671
Yeah my Mrs smax has temp gauge and always look for it when I get back in the jimny. Small things eh??!!!
Cheers
