Engine removal
- Longman
11 years 8 months ago #139769
by Longman
Replied by Longman on topic Engine removal
Yeah will be doing at work over a weekend I will let you know when
- mickt
11 years 8 months ago #139777
by mickt
Replied by mickt on topic Engine removal
j999pre:- I bought a full gasket kit and there is a sump gasket in that along with everything else!
11 years 8 months ago #139782
by kirkynut
Replied by kirkynut on topic Engine removal
I wouldn't take the gearbox out as well to be honest. You'll have a big lump to put back in with both together!
It'll not be fun putting the engine and box back together in or out of the car but I think I would prefer to leave the box in the car so there is much less of a lump to lift over and into the engine bay. I've done it before on my old SJ with no issues and the Jimny is not much different. I did that on my own so if you have helping hands it ought to be fine, just one of those jobs that might make you swear a bit!
11 years 8 months ago #139788
by j999pre
Interesting Mick, I've probably done 10 to 12 g13b or g16b jimny engines and none had a sump gasket? No harm in fitting one I suppose??? Maybe that is for the earlier Sammy engines and its a generic set?
Grey pick up Jimny
Replied by j999pre on topic Engine removal
mickt wrote: j999pre:- I bought a full gasket kit and there is a sump gasket in that along with everything else!
Grey pick up Jimny
- mickt
11 years 8 months ago - 11 years 8 months ago #139790
by mickt
I think it did cover a few of the Suzuki's
Ref the gearbox I meant to use it to align the clutch and then refit each separately.
Last edit: 11 years 8 months ago by mickt. Reason: Further text info
11 years 8 months ago #139799
by Rhinoman
Replied by Rhinoman on topic Engine removal
I wouldn't bother with the sump gasket, the sump isn't designed for one and it will squeeze out when you tighten the bolts.
Time to create page: 0.098 seconds
