intermittent mechanical chatter
11 years 8 months ago - 11 years 8 months ago #139501
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
intermittent mechanical chatter was created by Paul4A
Hi,
We've just had my partner's old T registered Jimny repaired of multiple issues but something new has just started. Part of those repairs were renewal of vacuum solid and flexible pipes on the front for the four wheel drive system which now seems to be operating again.
The new problem is that four times now while driving along in two wheel drive there has been a mechanical chattering noise. The first time it was only for a second and I'd just put it into fourth gear so assumed I'd not engaged gear properly. The second and third time it happened I was in fourth gear and the chattering lasted for a couple of seconds. All three times up to then was about a minute or two after starting a journey from cold. Yesterday's fourth instance however was while cruising at 50mph in fifth gear after ten minutes of driving and it lasted about four seconds. I pulled over thinking it was the end of our journey but it stopped as quickly as it started.
I'm looking for suggestions as to what it might be. There is no feedback through the gearbox or steering but what sounds like metal on metal chatter is definitely not right. It's hard to pinpoint the source of the noise from the brief period that it happens but I'm tending to towards front right corner when in the driving seat. I'm a complete novice on these cars but have been reading about hub operations and wonder if it could be a problem hub (questioning that if in 2WD) or maybe something to do with the vacuum system.
Suggestions appreciated.
Paul
Paul
Last edit: 11 years 8 months ago by Paul4A.
11 years 8 months ago #139503
by facade
Replied by facade on topic intermittent mechanical chatter
Some people have reported that they have a hub trying to engage causing a noise.
I would have thought it would have been caused by a leaky vacuum switching solenoid valve rather than a sticky hub, as you'd expect it not to come & go if it was just stuck. However they normally use it as an excuse to swap to manual hubs rather than sort it out.
You could disconnect and plug the vacuum pipe from the manifold, exhaust the vacuum by engaging & disengaging 4wd a few times engine running, then take the hubs off, manually unlock them by pushing the centre inwards till it clicks, refit and see if you get the noise again.
The other source of a terrifying noise that scatters dogs & cats for miles is a loose heatshield on the catalyst beneath the passengers feet.
The following user(s) said Thank You: Paul4A
11 years 8 months ago #139712
by kirkynut
Replied by kirkynut on topic intermittent mechanical chatter
It could be as facade suggests but it could also be the transfer box chain making a noise if stretched. It's hard to determine sometimes but where does it seem to come from?
Time to create page: 0.112 seconds
