VVT front diff
- Johnniehec
Topic Author
- Thank you received: 56
11 years 8 months ago #138749
by Johnniehec
VVT front diff was created by Johnniehec
Hi Does anyone know if a 4.1 front diff from a 05 on VVT axle will fit, or can be made to fit, in a 2001 3.9 axle casing?
I believe the crown wheel may be a bigger diameter?
Cheers,
John.
Cheers,
John.
11 years 8 months ago #138751
by j999pre
Grey pick up Jimny
Replied by j999pre on topic VVT front diff
I thought but we're 4.3 the 4.1 diff is the auto?? Could be wrong though
Grey pick up Jimny
11 years 8 months ago #138770
by facade
Replied by facade on topic VVT front diff
Someone recently changed the front axle casing, and found that his diff wouldn't go in, had it machined to go in and reported that something sounded as if it were still catching.
I'm guessing a 4.1 diff has a bigger diameter crownwheel, I'd have thought you could file two notches in the axle to get it in, but it might catch on the filler plug side.
- Thank you received: 2004
11 years 8 months ago #138771
Replied by Lambert on topic VVT front diff
That was me. The axles do have notches to accept the crown wheel which need to be clearanced to get the bigger manual diff in. The additional noise I encountered was not related to the machining of the smaller axle.
Time to create page: 0.082 seconds
