ARB RD206 fail
- minare
20 Feb 2015 22:52 #138646
by minare
ARB RD206 fail was created by minare
Hey all,
I have fron diff lock, about 2 years old, RD206that workd just fine till few monthes ago.
i have kind of strange behavior of my front diff lock.
at first use, most of time, its engage and works perfectly with no compressor involving for about 10 min. the disengage after is also fine.
when i disengage and try to engage againg i notice that all the air goes out from the breather and no engage of the diff. i need to drive a a bit (didnt find kind of rule) to make it works again.
lately i notice that the ability to engage the diff lock after disengage became difficultly.
I must say that when i finally engage the diff lock, there is no air leak and the compressor works only every 10 min.
please advice, about the diagnose and solution
thanks
Guy
thanks
Guy
- TomDK
20 Feb 2015 23:05 - 20 Feb 2015 23:25 #138647
by TomDK
Replied by TomDK on topic ARB RD206 fail
Are you sure your compressor is working 100% as it should? Also are air lines airtight?
Last edit: 20 Feb 2015 23:25 by TomDK.
- zukiara
20 Feb 2015 23:14 #138648
by zukiara
Replied by zukiara on topic ARB RD206 fail
Mmm possibly the o rings inside the ARB leaking air
- minare
21 Feb 2015 10:34 #138674
by minare
Replied by minare on topic ARB RD206 fail
the problem is that the front diff sometimes engage with no leak and sometime not engage at all and all the atir goes out from the breather
by that time, the rear diff lock works just fine
- zukiara
21 Feb 2015 12:04 #138682
by zukiara
That's pointing more to the o rings inside the ARB, strip and replace the 2 o rings.
Time to create page: 0.092 seconds
