newbie with a problem
  • Daniel30
11 years 9 months ago - 11 years 9 months ago #138275 by Daniel30
newbie with a problem was created by Daniel30
Hi everyone im new to the site and apologies' if its in the wrong category, I have a 07 plate jimny and its the first 4x4 I have owned loving it to bits very quirky and cant wait to get some more mods for it I have general grabbers on it and the modular steels which make it look better and waiting for the funds for a 2" lift just for a bit of soft off roading, there are a couple of questions though - when I had it in four wheel drive a couple of weeks ago pulling into my drive slowly on a tight lock it felt like the left wheel was getting stuck on some thing and it didn't want to turn (if this makes sense)back in two wheel drive it is fine on the same lock,
The other question is what is happening in this picture attached is it bad news??
thanks for your time
Last edit: 11 years 9 months ago by Daniel30. Reason: me
11 years 9 months ago #138276 by mlines
Replied by mlines on topic newbie with a problem
1. Don't drive in 4 wheel drive on road or tarmac. If it still "pulls" on the steering when on mud or other loose surface then the CV joint may have failed.
2. Looks like the Kingpin Bearings have worn out in the picture.
  • the_goshawker
11 years 9 months ago #138277 by the_goshawker
Replied by the_goshawker on topic newbie with a problem
The main man above knows his stuff so try his ideas 1st
  • Daniel30
11 years 9 months ago #138280 by Daniel30
Replied by Daniel30 on topic newbie with a problem
so its bad news then :)
thanks for the reply better look into getting it sorted does anyone know any good garages in the Bromley/Kent area??
thanks
11 years 9 months ago #138295 by mlines
its only bad news depending on where you go. Its a straight forward and cheap process in itself. The parts are in the BigJimny store
www.bigjimny.com/store/index.php?_a=product&product_id=6
And there is a guide on how to do it.
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
It should take a competent DIY home mechanic a couple of hours and someone more experienced less than an hour to do. I am not a mechanic and I can do both sides in an hour now as I have had to do it so many times.
However, I have seen some garages quote £400 to £800 because they want to change everything (including in a couple of instances the ENTIRE axle). This is not right!
  • Daniel30
11 years 9 months ago #138301 by Daniel30
Very useful thank you I'll get some tools and give it a go cheaper than a garage, will I need the swivel seal thing?
Time to create page: 0.107 seconds
