Very fast tick over
  • Jabberwocky
11 years 9 months ago #138183 by Jabberwocky
Very fast tick over was created by Jabberwocky
Hi, I have a 02 plate 16v 1300 Jimny and have a problem with a very fast idle speed.
When the engine is started from cold it seems fine and ticks over about 900-1000 rpm. However it seems as soon as the engine reaches its normal running temp the tick over jumps to 2000 rpm and stays there. It the engine is revved the tick over drops very briefly back, but then jumps up to 2000 rpm again.
I have checked all the vacuum hoses, the PCV valve and also checked that the throttle valve is shutting fully and everything checks out OK.
Any ideas please?
11 years 9 months ago #138188 by j999pre
Replied by j999pre on topic Very fast tick over
idle control valve? Servo pipe split?
Grey pick up Jimny
  • Jabberwocky
11 years 9 months ago #138196 by Jabberwocky
Replied by Jabberwocky on topic Very fast tick over
The servo pipe is fine, I'm not sure where the idle control valve is? Is that the one that is connected to the water pump? And if so, is there any way of checking it?
  • Jabberwocky
11 years 8 months ago #139225 by Jabberwocky
I have narrowed the problem down to the idle control. I would like to take this out to clean, but noticed that there are two screws which look as if they need a special tool (my torx heads do not fit).
Does anyone know the type of tool I need and is it advisable to take it apart to clean?
11 years 8 months ago #139228 by facade
Replied by facade on topic Very fast tick over
Those are tamperproof torx, the tool is a torx bit with a hole in the middle.
About a fiver for a set of L shaped keys on eBay.
As to whether they are what you undo to remove it, I'm afraid I don't know.
No reason why it wont come apart for cleaning AFAIK.
  • Jabberwocky
11 years 8 months ago #139374 by Jabberwocky
Well I took the throttle body out and disconnected the Idle control valve to find it had stuck fast. Loads of cleaner and a good soaking later, it now works properly and the engine runs like a dream. B)
Time to create page: 0.103 seconds
