Fixed hubs problem?
  • Roland
11 years 9 months ago #138044 by Roland
Fixed hubs problem? was created by Roland
Hi guys I did the Kirkynut fixed hub mod today using a pair of small rubber bungs to lock the hubs exactly as in his write up on here. I didn't do anything with the vac pipes though as I thought I could sort them out at a later date to make a better job of it. Anyway when I select 4 wheel drive the light flashes or doesn't come on at all which is what it was doing anyway before I changed the hubs. This I could live with for now but the car wont go into 4 wheel drive and only the rear wheels drive it. I was parked with the rears on grass and fronts on concrete and when I put it in 4 wheel drive the rear wheels just slipped and spun and the fronts wouldn't pull the car at all? The car drives fine in 2 wheel drive on the road but has anyone got any idea why the 4 wheel drive doesn't work? Is it something to do with the vac pipes not being disconnected?
11 years 9 months ago #138045 by j999pre
Replied by j999pre on topic Fixed hubs problem?
Nope it must be how you have set the hubs to fixed.
Grey pick up Jimny
  • Roland
11 years 9 months ago #138047 by Roland
Replied by Roland on topic Fixed hubs problem?
Like I said I did them exactly the same as in the sticky write up that Kirkynut did. 10mm thick rubber spacers and I made sure everything went together properly too. The one thing I did notice is that the drive shafts seemed to be a long way inside the axle tubes at the front and I couldn't see how they would reach the inner drive spline of the hubs but assumed they would.
11 years 9 months ago #138049 by j999pre
The inner spline had to be pulled off the magnet to interlock with the hub. If that is all done and the bung is behind to stop it unlocking then the problem must lie with either a broken shaft/diff or transfer box
Grey pick up Jimny
  • Roland
11 years 9 months ago #138050 by Roland
That makes sense. I think I need to get under there and inspect things then. Thanks for your advise mate :)
  • Roland
11 years 9 months ago #138051 by Roland
Is there a chance that the diff is broken up and the drive shafts are "floating" around? When I was putting the hubs back on I remember thinking to myself "how do those drive shafts move out to engage with the splines in the hubs?"
Time to create page: 0.129 seconds
