Front end strange noise
  • Calcium09
14 Feb 2015 09:03 #137864 by Calcium09
Front end strange noise was created by Calcium09
Hey everyone,
Quick question for you all..
Whenever I drive over speed bumps I get a strange noise coming from the front of the car and think it is on both sides it almost Kaunda like something is loose, broken, snapped...
Anyone know what this could be? I know it's a vague description but not sure how else to describe,...
Thanks
  • TomDK
14 Feb 2015 09:28 #137866 by TomDK
Replied by TomDK on topic Front end strange noise
Perhaps you should take a look under the car.
Much easier than us guessing what it could be.
  • Calcium09
14 Feb 2015 09:51 #137868 by Calcium09
Replied by Calcium09 on topic Front end strange noise
I will do just thought I would ask here in case there is a common fault That people suffer from that would make it easier to look for
14 Feb 2015 10:37 #137873 by facade
Replied by facade on topic Front end strange noise
Broken anti roll bar link, broken spring, play in radius arm bushes, panhard snapped/bent & catching axle, panhard bushes worn, shock absorber loose/faulty.
Could even be a corroded and snapped mounting.
  • Calcium09
14 Feb 2015 12:54 #137901 by Calcium09
Thanks guys also just noticed it is leaking a bit of oil when I drove away... Could these problems potentiallybe related?
14 Feb 2015 13:18 #137907 by facade
Yes
You likely have the kingpin bearings gone, amazed you haven't got the associated wheel wobble and wandering steering.
Time to create page: 0.112 seconds
