Intermittent Misfire
  • McMahon
13 Feb 2015 19:31 #137839 by McMahon
Intermittent Misfire was created by McMahon
My wife's Jimny has developed an intermittent misfire, I suspect a failing coil pack but my problem is I cant find a replacement coil with the same part number.
The part number on the existing coil packs is 9G07-0371, can anyone tell me where I will find replacement coils with this part number or if there are alternatives available.
Her Jimny is a 2006 and I think its the M13A engine.
  • mickt
13 Feb 2015 20:30 #137840 by mickt
Replied by mickt on topic Intermittent Misfire
Try ebay item# 151163977846
  • McMahon
13 Feb 2015 23:43 #137853 by McMahon
Replied by McMahon on topic Intermittent Misfire
mickt wrote: Try ebay item# 151163977846
Thanks for your reply but this looks similar at half the price 301020570054
14 Feb 2015 08:17 #137859 by facade
Replied by facade on topic Intermittent Misfire
Assuming the first item is a genuine Denso part (by no means certain on eBay) it might last the car out, but the other will be made by Chinese children (who don't work nearly hard enough for my liking :) ) and you will be lucky if it lasts as long as a year.
You gets what you pays for in this world.
I suppose you could buy the cheapest, and swap it out to eliminate a faulty coilpack, then put the original back if it makes no difference, the coilpacks don't give much if any trouble, missfires can be caused by oil leaking into the plughole, I'm not sure why as oil is an insulator.
  • Paul_sterling
14 Feb 2015 08:59 #137863 by Paul_sterling
Replied by Paul_sterling on topic Intermittent Misfire
ive had an intermittent missfire on a Vitara caused by degrading plug leads, well in this case just one.
Paul.
