2" Body Raise
  • nick40
10 Feb 2015 13:18 #137469 by nick40
2" Body Raise was created by nick40
Hi All, I am considering raising my Jimny by an Inch or two, I don't really off road as such, but my day to day driving takes me into fields, very bad roads, forests and in the winter into a fair bit of snow, I have General Grabber AT's which are on standard size steel modular wheels and fill the arches a bit more than standard. The problem I have is if I have some weight in the back and hit a pothole at 30mph plus the wheel arch and tyre meet. Do you think a body raise is the answer? If so what are the pitfalls of this, If I were I would use the longer brake hoses and steering column extension, but are there any other things to consider, someone told me I would need to relocate the metal body of the front and rear bumper as this is welded to the chassis, any advice gratefully accepted.
Nick
  • Russ-41
10 Feb 2015 13:44 - 10 Feb 2015 13:47 #137477 by Russ-41
Replied by Russ-41 on topic 2" Body Raise
Nick,
What size are your tyres?
If your not doing any serious off roading, the best option would probably be smaller tyres :woohoo:
I run 195/80/15's which are a little taller than standards but slightly narrower. [strike]They have less "bounce" round corners so feel better than the 205's however [/strike] (actually this is probably just because I've gone from unbranded budgets to reasonable quality) my speedo is now "out" as they're so much bigger. It actually reads exactly what my GPS speed reads, it used to be 5-10% behind (as most cars are I think)
My fuel consumption "appears" to have gone down 5-10% but this is really just the change in speedometer.
Last edit: 10 Feb 2015 13:47 by Russ-41.
  • nick40
10 Feb 2015 13:53 #137478 by nick40
Replied by nick40 on topic 2" Body Raise
Thanks for your reply, Changing the tyres is not really an option as I would spend half my day stuck in mud, when I say I don't off road, what I mean is I don't do it for entertainment but my day to day driving means I spend a lot of time on mud tracks etc, I don't go over very rocky or heavily rutted ground, just tracks used by tractors really, The General Grabbers do the Job brilliantly so not sure I would change them, I dont think I really need uprated springs either, but I might be wrong
  • Russ-41
10 Feb 2015 14:06 - 10 Feb 2015 14:07 #137480 by Russ-41
If general grabbers do the job, I strongly suspect you can afford smaller tyres without losing grip but I'm a novice here.
What size are the tyres, that's really what people are going to want to know to work out if you can get away with a body lift of some sort or need to go further. Also how much weight are we talking about in the back - perhaps just a 1.5" spring spacer kit from Bits4vits will do the job.
Its simple to fit, very cost effective and limits spring travel as you use the original spring and shocks, I've just fitted mine and it was a doddle, the most difficult bit was removing the 2 M10x1.25p nuts from the tops of the front shocks - one is locked down on the other - I managed it with an open ended spanner and an adjustable + a week in advance I WD40'd everything a little. This is much easier than a body lift and can be done in a few hours.
Last edit: 10 Feb 2015 14:07 by Russ-41.
  • nick40
10 Feb 2015 16:02 #137491 by nick40
Hi Russ
The Tyres are 225 70 15's and the kind of weight I am on about is a boot full of firewood and my Mrs in the back, Dog travels in the front, to be fair its unusual for me to have the Mrs in the back of the Jimny its usually just me and the Mutt.
  • Russ-41
10 Feb 2015 16:44 #137495 by Russ-41
225/70/15's are almost the same diameter as my 195/80/15's (+28mm, mine are +25mm) so it must be a factor of the extra width.
I'm assuming its the rear that's rubbing? even on standard shocks and springs with a boot FULL of tools, spades, wellies, camping gas, sleeping bags etc. I've not had any rubbing, so it must be a factor of the width and not the diameter.
According to the tyre size thread just going to 215/70/15 will require a 2" lift as a minimum or lots arch cutting!
At a guess you may be looking at a 3" lift which is getting pretty tall, your centre of gravity will be pretty drastically altered.
Personally on my budget, I think I'd try a 1.5" lift on the cheap first, then if it still rubs perhaps reply to davert85's wanted/swaps advert :P - or try a 1" or 2" body lift.
Time to create page: 0.117 seconds
