Help wit issue on hubs
  • apache
11 years 9 months ago #137387 by apache
Help wit issue on hubs was created by apache
I have been having an issue when driving along the nearside hub keeps trying to engage I have renewed all the pipes and appear to have a constant vacuum to one of the lines which goes to the side of the hubs Any Ideas
11 years 9 months ago #137388 by funkyjimny
Replied by funkyjimny on topic Help wit issue on hubs
4wd light isnt on on the dash is it ? just checking..
  • apache
11 years 9 months ago #137390 by apache
Replied by apache on topic Help wit issue on hubs
light come on when put into and is steady but doesn't light up when it tries to engage always happens when coasting up to roundabout and sound like hub is about to explode
  • apache
11 years 9 months ago #137392 by apache
I thought the issue must be something to do with pipes as had repaired them last year so decided to replace them all.
Having read the How To Section am I correct in thinking the system should only apply a short pulse of vacuum to engage and another to disengage
11 years 9 months ago #137411 by facade
Replied by facade on topic Help wit issue on hubs
Yes, the solenoid valve only activates for about 10 seconds total when first engaging or disengaging FWD.
The valves do get sticky, not close off properly and allow a permanent leak. One of mine went sticky, I freed it off with a squirt of GT-85 into the ports and applying a battery to the terminals a few dozen times.
  • apache
11 years 9 months ago #137515 by apache
Thanks,
I pulled solenoid valve off last night and kept working it off 12v battery on bench with liberal squirts of release fluid back together now and all fine Ta.
Along with 6m of silicon vac hose and 2 x T's to replace steel pipes, now working better than has in last 10 year :-)
Time to create page: 0.092 seconds
