Stuck in 4wd high!
  • stumfelter
01 Feb 2015 12:00 #136615 by stumfelter
Stuck in 4wd high! was created by stumfelter
Hi all, my problem is basically this- sat outside checking the hubs on my 07 jimny pressed 4wd switch and hubs engaged and solid green light, then pressed 2wd and hubs disengaged and no 4wd light then pressed 4wd switch again and hubs clicked in but when I pressed 2wd button green 4wd light started flashing and hubs wouldn't disengage and was stuck in 4wd. I took the engaging mechanism out of the hubs so that I could use the car on road but the front propshaft is still being driven. Tried blocking off both vac pipes where they connect to the metal pipes but still can't get 2wd and green light still flashing- any idea's anyone?
  • Basketcase
01 Feb 2015 12:07 #136616 by Basketcase
Replied by Basketcase on topic Stuck in 4wd high!
I used to get that problem on my 07 reg, I used to have to rock it forwards and backwards a little bit maybe 5-10 yards before it would give a loud clunk out of 4wd
  • stumfelter
01 Feb 2015 12:36 #136617 by stumfelter
Replied by stumfelter on topic Stuck in 4wd high!
Unfortunately I tried that and it didn't work, it's almost as if the 2wd switch isn't sending a signal to the actuator on the transfer box. does anyone know of a way to test for this- wire colours, readings at actuator etc?
01 Feb 2015 22:25 #136659 by auchenblae
Replied by auchenblae on topic Stuck in 4wd high!
As soon as the light flashes it locks the ecu that runs the 4WD system.
It stops either solenoid valve opening so you cannot get between 4wd and 2WD either way or stops you getting into low box.
Its a pain to get at but if you undo the connector to the vacuum switch and short it . You will turn off the green light.
It is a pain.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
The following user(s) said Thank You: stumfelter
  • stumfelter
02 Feb 2015 19:34 #136749 by stumfelter
Finally managed to sort it! I was convinced it was an electrical problem so I thought where would be most susceptible to any problems then realized Suzuki in their wisdom had put a bunch of connections at the back of the transfer box. I took the mounting plate off then disconnected the plugs and sockets and gave each a liberal dose of contact cleaner - after a cup of coffee and a fag to give it time to evaporate I rebuilt it all and crossed my fingers. Hurrah, no flashing green light, solid light 4wd, no light 2wd, I can even hear the controller clicking under the dash! Hopefully this will be of help to someone as I trawled the net and have never seen this cure for what must be a common problem.
Thanks to all who replied, Stu.
Time to create page: 0.087 seconds
