Rear seats removal.
28 Jan 2015 08:23 #136240 by BGBrit
Rear seats removal. was created by BGBrit
Hello all!
From a recent photo of a Jimny with the seats removed and a superb floor in it's place, it has motivated me to do the same to mine (2009)on a temp basis. I need the seats in for the winter months but more floor space in the rear during the summer months, to take tents and other camping equipment.
Before I go in blind and :silly: possibly doing damage, can anyone who has done the same give me some advice how to go about it in a clever manner. The mot is due mid Feb so I'll obviously do it after that date.
Cheers...
28 Jan 2015 09:05 #136241 by Busta
Replied by Busta on topic Rear seats removal.
I've never done it on a newer Jimny but it's simple a case of flipping up the seat bases, finding the bolts that hold the seats in and removing them. They are probably 14mm bolts. Some may be under little bits of plastic trim.
There is no issue with the MOT. They will just put 'no rear seats fitted at time of test'.
The following user(s) said Thank You: BGBrit
  • gusthegorilla
28 Jan 2015 09:51 #136243 by gusthegorilla
Replied by gusthegorilla on topic Rear seats removal.
BGBrit wrote: Hello all!
Cheers...
Hello, BGBrit
As I said in a previous thread which you may not have seen, the rear seat-fixing arrangement changed around the end of 2005...prior to that, the seat swab was in 2 pieces and folded forwards independently of each other, and were bolted to the floor in 4 places at the leading edge.
After that, the seat swab became a cheap and nasty one-piece affair which was fixed to the floor with push-on clips, and the seat backs folded forward over the top, which meant your floor then looked like a ski slope. It was crap, to be frank.
When I did my floor, I removed everything inc. seat belts, and welded 4 M12 nuts to the metal in strategic areas of strength. Then having fabricated the new base from 10mm marine ply and tailored it to fit, back-marked the 4 nut positions, drilled and countersunk the ply....you get the picture....3mm non-slip rubber mat cut to suit ....job done.
So, in essence, this is a permanent fix, but if you want to reinstate the seats on a couple of occasions a year, it is reversible, albeit time-consuming and a bit of a ball-ache really!!! You would obviously have to leave the seat belts in position, just in case :)
Hope this is of use.
Chris
28 Jan 2015 12:01 #136254 by Halford
  • jim
28 Jan 2015 13:33 #136263 by jim
Replied by jim on topic Rear seats removal.
What I have done at the moment is just remove the lower base as it just clips in and out in one piece. This allows the backrest to fold flatter with rear head restraints removed.
To remove the later style base give a firm sharp tug either end where it clips into the floor and that's it, it can be replaced in seconds if you do need to carry passengers.
It's a bit of a compromise.
30 Jan 2015 10:39 #136447 by BGBrit
Replied by BGBrit on topic Rear seats removal.
Thank you all for the replies and tips and photos,, so I can now go ahead with confidence!
I'll try first removing the seat bottoms as Jim suggested and see if this is ok as it would be easier to restore, if not I'll move on to Chris's method for full removal (Good job done bytheway).
Thanks for the photos Halford as a picture says a thousand words..
I'm a newbe here and I must say it's been a joy and a great confidence boaster to have so many people I can call upon for advice, I hope I can help too when my experiences with the Jimny grows. I hope to post my newbe intro soon, intro myself and my Jimny. :)
Regards
Tony.
The following user(s) said Thank You: gusthegorilla
Time to create page: 0.103 seconds
