Sudden Low Speed Vibration
- Floppydog
25 Jan 2015 07:35 - 25 Jan 2015 07:48 #135960
by Floppydog
Sudden Low Speed Vibration was created by Floppydog
Hi , Our Jimny has developed a bad vibration at low speed , it completely disappears at higher speed . I have had a quick look and nothing appears to be loose / falling off. No noise if you coast , no clutch noise either such as trust bearing . I think I can hear a strange wishing noise but not certain on that
I am thinking propshaft , rear engine mount , or may be transfer box .
Can anyone shine any light as to my starting point and how to check the parts.
The Jimny is a 2002 hard top with 16v chain engine and has done about 80k.
Thanks in advance.
Thanks in advance.
Last edit: 25 Jan 2015 07:48 by Floppydog. Reason: spelling
- gusthegorilla
25 Jan 2015 08:32 #135961
by gusthegorilla
Replied by gusthegorilla on topic Sudden Low Speed Vibration
What do you mean by 'Low Speed?'
Would it be round about 40-45mph, by any chance?
- Floppydog
25 Jan 2015 08:41 #135963
by Floppydog
Replied by Floppydog on topic Sudden Low Speed Vibration
Hi anything from start to around the 40mph mark .
Its getting worse over a short mileage I did 20 miles yesterday .
It was fine Friday or at least was not apparent.
Thanks for replying.
- gusthegorilla
25 Jan 2015 08:50 #135966
by gusthegorilla
In all probability you have a problem with your kingpin bearings...relatively easy fix...others on here will be able to guide you better than I, but suggest you study THE DEATH WOBBLE THREAD at the top of page 1.
Good luck, and welcome
- Floppydog
25 Jan 2015 09:11 #135969
by Floppydog
Hi again and thanks .
I do not get any vibration through the steering wheel , it more like a exhaust vibrating on the car floor . I tried to locate the sound and would appear to come from the center of the car , I am aware that it could come from anywhere really . So could this still really be the king pin bearings ? ..
Thanks
Thanks
- gusthegorilla
25 Jan 2015 09:27 - 25 Jan 2015 09:46 #135971
by gusthegorilla
If nothing through the steering wheel, then kingpin bearings are almost certainly NOT your problem. It's the fact that it appears about 40mph that threw me.
I was a little hesitant to say what I said in the first place because kingpin faults don't normally appear so abruptly.
As before, others will have a better idea ...... apologies if I appeared to be alarmist, didn't read it properly in the first place!! :whistle:
Last edit: 25 Jan 2015 09:46 by gusthegorilla. Reason: Missing statement
Time to create page: 0.098 seconds
