Hubs leaking
  • rolfe
24 Jan 2015 19:30 #135936 by rolfe
Hubs leaking was created by rolfe
Hi all. I have lots of oil and grease coming out from the inside of the hub on both sides. Is this the wheel bearings or the kingpin bearings. Thanks and hope some1 can help.
  • stumfelter
24 Jan 2015 20:00 #135941 by stumfelter
Replied by stumfelter on topic Hubs leaking
Hi, jack the wheel up and hold the wheel at twelve and six o clock and try to push the wheel in and out, any movement and it's probably your kingpin bearings.
  • helijohn
24 Jan 2015 23:27 #135951 by helijohn
Replied by helijohn on topic Hubs leaking
stumfelter wrote: Hi, jack the wheel up and hold the wheel at twelve and six o clock and try to push the wheel in and out, any movement and it's probably your kingpin bearings.
What he said but personally I don't jack it up. Just grab the top of the tyre with two hands and push pull. You'll feel movement if it is the pins. If so the seal on the shaft is deformed as the shaft has pressed on it allowing oil to seep past. It is very common.
  • rolfe
25 Jan 2015 14:43 #135990 by rolfe
Replied by rolfe on topic Hubs leaking
hi thanks all for ur replys, i think its more movement left and right, and i right in saying this is the wheel bearings,
  • helijohn
25 Jan 2015 17:24 #136007 by helijohn
rolfe wrote: hi thanks all for ur replys, i think its more movement left and right, and i right in saying this is the wheel bearings,
Possibly but the factor that is nearly always a giveaway clue is the leaking. ;)
  • rolfe
25 Jan 2015 18:47 #136013 by rolfe
What do u reckon its still the kingpin bearings then mate
Time to create page: 0.120 seconds
