small plasma recomendations
  • mark 88
11 years 9 months ago #135839 by mark 88
small plasma recomendations was created by mark 88
hi all can anyone recommend a plasma cutter that will run off 13 amp supply
thanks all
  • mickt
11 years 9 months ago #135850 by mickt
Replied by mickt on topic small plasma recomendations
I have one that has its own compressor. Italian. About £500 if my memory serves. I will dig it out and give you the name later today.
11 years 9 months ago #135854 by Busta
Replied by Busta on topic small plasma recomendations
I have a tec-arc 56i which runs off 16 amps but you can use it on 13amp if you are only cutting thinner stuff. They do smaller version too which is just 13 amps.
I haven't used it a great deal but so far it seems pretty good. It uses a separate compressor. The torch is a copy of an old Hypertherm so tips and electrodes are readily available and quite cheap.
  • mark 88
11 years 9 months ago #135944 by mark 88
Replied by mark 88 on topic small plasma recomendations
cheers lads thanks
  • mickt
11 years 9 months ago - 11 years 9 months ago #136072 by mickt
The make of my plasma is Telwin (made in Italy) and the model name is "Technica Inverter Plasma 34 Kompressor" I bought through the ebay about 4 years ago.
There is a used one for sale on there at this time item no. 261746624319
Last edit: 11 years 9 months ago by mickt. Reason: Further info added
