do i need an extra battery for winch
- mark 88
22 Jan 2015 14:25 #135703
by mark 88
do i need an extra battery for winch was created by mark 88
hi all im thinking of fitting a champion winch will i need a second battery to power it ?a friend of mine has winch on his defender and he has only one battery, but its considerably bigger than a jimnys battery
any advice would be great thanks
- TomDK
22 Jan 2015 16:17 #135721
by TomDK
Depends on your budget and use of winch.
A single good quality battery is far better than two batteries of poor or mediocre quality.
Replied by TomDK on topic do i need an extra battery for winch
mark 88 wrote: hi all im thinking of fitting a champion winch will i need a second battery to power it ?a friend of mine has winch on his defender and he has only one battery, but its considerably bigger than a jimnys battery
- mark 88
22 Jan 2015 17:03 #135728
by mark 88
Replied by mark 88 on topic do i need an extra battery for winch
just to pull me out of a ditch every now and again
thanks all
thanks all
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
22 Jan 2015 21:54 #135786
by funkyjimny
Replied by funkyjimny on topic do i need an extra battery for winch
As said above, fine with std battery then, if your engine is not running don't expect it to last long though, twin battery setups last a bit longer.. I've never had anything but the single std battery and never had a problem as long as engine is running. On longer pulls winch in for a couple of minutes tops then let battery re charge for a few minutes before winching again.
Gary
Gary
Time to create page: 0.084 seconds
