any help again guys please ..
  • whittleos
11 years 9 months ago - 11 years 9 months ago #135683 by whittleos
any help again guys please .. was created by whittleos
hi again all . sorry if this is in wrong section if so could you please move it to correct one thank you ..
i am wanting to put 4 triangulated 4 link set up on my jimny now i have been looking online for idea's plans etc .. am i correct in thinking if i have it triangulated i can do away with pan hard ... could i use the mount i have on chassie now and have two arms going to axle as they are now with the radiouse arms atm but with rose joints on then fromt there go from near middle of diff to inside of chassie or would i need a panhard rod then ? any body have a site they know of that gives propper info as seems a lot i have found say one thing next says a other so confused my self now . so like photo but instead of top bars going to chassie put them on bottom as if they are now then make top once go into middle . if i can do this would this also mean i can do away with panhard ...hope this makes some kind of seance to you all .
Last edit: 11 years 9 months ago by whittleos.
11 years 9 months ago #135686 by Busta
Replied by Busta on topic any help again guys please ..
If you do it like in the picture you won't need a panhard. The bars are diagonal from the axle and cross over each other, stopping any side to side movement. Triangulated or crossed= good. Parallel = bad.
If you do it as you describe the bars will all be nearly parallel, at 90 degrees to the axle. No triangles so you will need a panhard.
  • whittleos
11 years 9 months ago #135737 by whittleos
Replied by whittleos on topic any help again guys please ..
thanks for your replay . . you say one in pic would work with out panhard rod but looks to me like top to are stright and bottom two are on a angle . so if i had two running stright and then two to middle like top of diff and then to chassie woul that not work and do away with panhard rod . ?
  • whittleos
11 years 9 months ago #135739 by whittleos
also . the vitara has two arms straight then a single link in middle that it pivets on . so if i where to do same put two to chassie then two from near as possible to the mounts where the radiouse arm gose then from there to middle of jeep this would in hand do it would it not ? or my been brain dead
  • whittleos
11 years 9 months ago - 11 years 9 months ago #135741 by whittleos
so if i where to do it like that ? two straight and two making triangle this would work would it not as it will not be able to have side to side movement ? or even the other pic where like a haynes pic
Time to create page: 0.089 seconds
