Hub question for a newbie without a scooby!
  • Whippersnapper 86
20 Jan 2015 23:44 - 20 Jan 2015 23:47 #135591 by Whippersnapper 86
Hub question for a newbie without a scooby! was created by Whippersnapper 86
Ok firstly sorry if this has been mentioned by people before but being a typical girl I don't know a plug from a bulb! A while ago some
Kind member on here had a look at my hubs for me as it appeared to not be going into 4WD
He took the hubs apart and made sure they weren't locked into 4WD then put them back on and did the lil gear stuck (sorry not at all techie with the lingo!) the car didn't appear to engage however on taking the hubs apart the right hand side Hub had engaged into 4WD however the left side had not!
He came to the conclusion it may be the vaccum hubs and suggested ditching the hubs for manual ones anyway.
Obviously I've never bothered getting it fixed but with the recent snow I'm realising how crap my lil Jimny is without this handy function!
So apologises if this has been asked before but what should I do now,more importantly is there anyone in the south/ West Yorkshire area that may be able to fix this for me?
I have also noticed a strange juddering sound and am not sure if it's coming from the exhaust or the gear box can anyone shed any light on this too??
Thank you
Last edit: 20 Jan 2015 23:47 by Whippersnapper 86.
21 Jan 2015 00:19 #135593 by Busta
In the short term, DOING THIS will ensure you have 4wd when you need it if there's snow.
You can then either
1. leave it like that forever (this is what I'd do)
2. Find the problem with the vacuum and get it working like it should
3. Fit manual hubs which mean you have to get out and lock them every time you need 4wd (unless you intend to leave them locked, in which case do 1. instead)
You'll need to be more specific about the juddering sound. Does it judder all the time, or just in certain gears, or at certain engine revs?
  • Whippersnapper 86
21 Jan 2015 00:39 #135594 by Whippersnapper 86
Replied by Whippersnapper 86 on topic Hub question for a newbie without a scooby!
It's like a juddery, grunty sound noise is there quite often but less so at speed.
As for the 4WD I thought it knackered the car up driving it permanently in 4wd when it's not needed?
I don't have the tools nor the bottle to start pulling, cutting and grinding bits of the hubs. Are the vaccum hubs expensive to repair?
  • Yellostreak
21 Jan 2015 03:23 #135596 by Yellostreak
Replied by Yellostreak on topic Hub question for a newbie without a scooby!
It's only in 4wd when you select it regardless of whether or not the hubs are locked... If you were closer to me I'd take a look for you...
21 Jan 2015 08:11 #135600 by Busta
Yes, the hubs are a secondary part of the 4wd system so can be left locked all the time. It's only when you move the 4wd lever/press 4wd the button (depending how old you Jimny is!) that the car sends power to the front wheels.
  • Blitz
21 Jan 2015 12:30 #135613 by Blitz
I didn't know that. So why do the hubs lock and unlock. Ie what's the disadvantage of running with perminant
Locked hubs ?
Thanks for the info
Time to create page: 0.096 seconds
