Newbie questions.
  • stumfelter
11 years 9 months ago #135559 by stumfelter
Newbie questions. was created by stumfelter
First of all hello to all on the site. I have recently bought an 07 plate Jimny and have a couple of problems!
1, Is it possible to remove the hubs far enough to change the kingpin bearings as it is fitted with ABS brakes.
2, Is it possible to remove the sump with the engine in as it is porous and I want to weld a plate on (or anyone near to Derby got a second hand one.)
3, The radio is asking for a code and in the owners manual there is a 4 figure code but it includes the numbers 8 and 0 and the push buttons are 1-6!
Any help is gratefully received and no doubt more questions will be asked by me!
  • X8GGY
11 years 9 months ago - 11 years 9 months ago #135566 by X8GGY
Replied by X8GGY on topic Newbie questions.
Welcome Stumfelter!
I'm fairly new to Jimny's, but can answer Question 1 for you...
Yes! ;)
Just remove the ABS sensor from the backing plate and the hub can be completely removed... I followed Martin's excellent KingPin guide (linked in my blog below) when I was changing the diff and shafts in my front axle...
You can see the photos of the ABS hub being dis-assembled here -
www.bits4vits.co.uk/store/lsd-into-front...-axle-/blog_281.html
And here is Martin's KingPin guide here -
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
Hope that helps...
Dave
Last edit: 11 years 9 months ago by X8GGY.
  • stumfelter
11 years 9 months ago #135568 by stumfelter
Replied by stumfelter on topic Newbie questions.
Thanks.
  • BigAndy
11 years 9 months ago #135569 by BigAndy
Replied by BigAndy on topic Newbie questions.
Welcome along!
Regarding No.3, are there any directional buttons to count the numbers up/down then move right to the next digit?
  • stumfelter
11 years 9 months ago #135572 by stumfelter
There are up and down arrows for the cd tracks so perhaps that is the answer! I'll try it tomorrow, thanks.
  • NineCherries
11 years 9 months ago #135577 by NineCherries
Replied by NineCherries on topic Newbie questions.
Normally you'd press button 1 repeatedly for the first digit, button 2 for the second digit and so, I've not got my manaul to hand to confirm that the case on a jimny though. Hope this might help.
Time to create page: 0.086 seconds
