Help with separating engine and gearbox
  • a4ndy
11 years 10 months ago #135452 by a4ndy
Hi all,
I am currently replacing the engine in my Jimny and had the engine lifted with the crane but i appear to be pulling the gearbox out with it... i have removed two nuts and two bolts that hold the engine and the gearbox together (two bolts from top of box and two nuts at around 7 and 5 o'clock on the front side on the block that come from the gearbox.) i have also removed the small plate from the bottom section of bell housing.
am i missing anything? is there a bolt that needs to be removed from the starter or something that would be holding the box and the engine together? i can see the flywheel on the passenger side but the drivers side remains fully closed.
thanks
andy
  • Flameboi201
11 years 10 months ago #135454 by Flameboi201
Replied by Flameboi201 on topic Help with separating engine and gearbox
Starter mate
  • a4ndy
11 years 10 months ago #135455 by a4ndy
Replied by a4ndy on topic Help with separating engine and gearbox
Flameboi201 wrote: Starter mate
Thank you very much!
superfast response too :)
its been doing my head in today... god that starter is in a ridiculous place... :/
I hope i haven't damaged anything by moving the box forward... it come forward a good couple of inches - although, if i haven't damaged anything, i wish id done it earlier to get better access to fuel lines and bell housing bolts :)
Time to create page: 0.070 seconds
