Hubs again!
  • Reloaded
17 Jan 2015 10:01 #135317 by Reloaded
Replied by Reloaded on topic Hubs again!
troggy wrote: 61 views!
I know that YOU reading this right now know the answer!
'Manual hubs' is the answer mate.
17 Jan 2015 11:16 - 17 Jan 2015 11:17 #135324 by facade
Replied by facade on topic Hubs again!
If you blow into the spigots on the swivel housing, then the frewheel hub will work in the backwards sense, and move the wrong way, don't use an airline as you will likely pop a seal.
If you can huff&puff forever then most likely your wheelbearing is on the way out, as the wheelbearing seals the passageway.
There is also a rubber seal in the outer hub, that wipes on the shiny collar of the hub nut for the outer seal.
Last edit: 17 Jan 2015 11:17 by facade.
The following user(s) said Thank You: troggy
  • Grego
17 Jan 2015 13:17 #135329 by Grego
Replied by Grego on topic Hubs again!
Mick C wrote: 'Manual hubs' is the answer mate.
Nearly 18 hours for that to be said, getting slow on here :laugh:
  • troggy
18 Jan 2015 14:31 #135390 by troggy
Replied by troggy on topic Hubs again!
Thanks all, I could spend many hours searching for the problem I guess.
It's a shame as I would like the hubs to work as intended, but I guess it's going to be manuals in the end.
Trouble is I aint got a ton thirty right now! :dry:
  • Yellostreak
18 Jan 2015 15:13 #135394 by Yellostreak
Replied by Yellostreak on topic Hubs again!
so have you checked that in and out of 4x4 you are getting a vacuum at the flexi's that go into the swivel?? (need engine running obviously!)..
if yes then its probably easier to take a chance on some second hand hubs.. most people change them because they want to be sure they are in 4x4 when up to the mirrors in mud..
if your not getting a vacuum to the hub change them to manual... I've got a pair of spacer rings you can have if you can find a pair of 410 hubs second hand..
18 Jan 2015 17:12 #135402 by Busta
Replied by Busta on topic Hubs again!
I think your problem will be simple to fix if you persevere. Have you checked the wheel bearings?
Save the hassle and cost of manual hubs by locking the vacuum ones, as described in Kirkynut's thread. You don't gain a lot by having the front hubs freewheeling anyway.
