Front engine mounts
  • exlandyman
11 years 10 months ago #135214 by exlandyman
Front engine mounts was created by exlandyman
Hello,
Is using a bottle jack (with some wood to spread the load) under the sump an OK way to secure the engine while I replace each mount in turn? If not is there a preferred way?
Thanks (and first post so Hello!)
Cheers,
Chris
11 years 10 months ago #135224 by facade
Replied by facade on topic Front engine mounts
Use an engine hoist to lift it.
The preferred way is likely one of those support bars that go across the engine and sit in the shut line of the bonnet.
On a normal car, I'd lift via the sump, but the jimny has a special sump made from extremely rusty metal, it will likely make it leak ;)
The following user(s) said Thank You: exlandyman
  • exlandyman
11 years 10 months ago #135251 by exlandyman
Replied by exlandyman on topic Front engine mounts
Nice one. Cheers.
