Copper washers for front brake hoses
  • CJV8
15 Jan 2015 11:34 #135151 by CJV8
I've just put a set of recon calipers on the front of our Jimny (from the BigJimny store, cheers Martin), but when I took the old ones off there weren't any copper washers on the hose coupling / banjo bolt.
Should there have been?
If they are required, can anyone tell me what size (ID / OD) of washer is required, I'm at work so don't have a caliper at hand to measure.
Cheers,
CJV8
15 Jan 2015 21:25 #135208 by kirkynut
Are you sure they are not there but just covered in dirt and stuck on the pipe and caliper?
15 Jan 2015 21:35 - 15 Jan 2015 21:36 #135209 by mlines
These???
PM me if you want them.
Last edit: 15 Jan 2015 21:36 by mlines.
  • CJV8
16 Jan 2015 09:31 #135241 by CJV8
Replied by CJV8 on topic Copper washers for front brake hoses
There definitely weren't any already there, I had a good poke about as I've had the same issue with a sump plug (different vehicle) where it gets discoloured and covered in grime.
Martin, they're exactly what I'm after. PM on its way.
Cheers,
Chris.
16 Jan 2015 17:57 #135289 by mlines
In the post
Sent from my Nexus 5 using Tapatalk
  • CJV8
19 Jan 2015 08:50 #135483 by CJV8
They arrived first thing Saturday so got them fitted and the brakes bled in no time.
Cheers Martin, great service as ever.
Time to create page: 0.092 seconds
