Steering (Not Death Wobble)
  • gary410
11 years 10 months ago - 11 years 10 months ago #135149 by gary410
Steering (Not Death Wobble) was created by gary410
I don't know if anyone has seen this, if it's normal or something needing repair or adjustment. When the steering is full left hand lock the front of the car dips.
There's no noticeable dip on right hand lock and there's also no clonks, bangs, groans or other strange noises on left hand lock, just the dip.
Suspension on the car is standard, tyres are standard Bridgestone Duelers.
I have an advisory on the mot (two months ago) that there is slight play on the off side king pin and it has a slight wobble at 45mph.
Any suggestions much appreciated.
Last edit: 11 years 10 months ago by gary410. Reason: A dyslexic walked into a bra.
  • gary410
11 years 10 months ago #135187 by gary410
Replied by gary410 on topic Steering (Not Death Wobble)
I have just over 2 turns of the steering wheel to the left and about 1 3/4 turns to the right. Is it possible that the pitman arm in not centred on the steering box ? or has the steering box output shaft a large spline so the pitman arm will only fit on centred ?
Any help/advice as I don't want to start pulling things apart if not needed.
11 years 10 months ago #135223 by facade
Replied by facade on topic Steering (Not Death Wobble)
The steering lock stops are in the steering box, so it is possible to turn the hub too far and have problems with the
cvjoint if the hubs are engaged.
Centralise the steering wheel to midway between the two end positions and then adjust the drag link (from steering box to hub) to straighten the wheels.
Never looked for or noticed any dip when on lock so I've no idea if it is normal I'm afraid.
11 years 10 months ago #135231 by Halford
Replied by Halford on topic Steering (Not Death Wobble)
not sure if this is helpful ............ :unsure:
I had a left-hand lock dip issue a while back and it was resolved by getting the front wheels laser tracked at ATS for £30.
the issue only developed after the front nearside tyre had developed some wear on the outer edge (arising from oo many right hand bends = roundabouts), obviously the isue is more pronounced on AT tyres and as they have a more defined drop-off edge than most road tyres.
so ineffect the combination of a slight worn tyre edge and slightly out tracking meant the car would literally fall-off over the tyre edge, bit like a wobbly clown car :laugh:
  • gary410
11 years 10 months ago #135242 by gary410
Thanks for the replies facade, Halford.
facade If I adjust the drag link to centre the steering box the steering wheel would not be straight. Is there another way to centre the steering wheel other the taking it off and putting it back on straight.
Halford the near side tyre is quite worn on the rim and theres a little bit of play
in the king pin so this may be the cause of the dip. So I think new tyres, king pin and alignment before I do any adjustments to the drag link.
Any advice on tyres for mainly road use, I fancy all season so able to do a bit of snow, ice and light mud (getting into my garden up the village green)?
  • youwin1000
11 years 10 months ago #135257 by youwin1000
Replied by youwin1000 on topic Steering (Not Death Wobble)
had the same problem once, it is the alignment,
its when one wheel cant turn any more because its already turned as far as it will go to one side.
you can check by looking under the car.
when the body of the car then "dips" to the side its the bushings in the front track bar flexing.
Time to create page: 0.088 seconds
