starting issues and the cure
11 years 10 months ago #135086
by robs5230
standard jimny - for now
starting issues and the cure was created by robs5230
had some real trouble this year with starting the jimny. early on this year the starter failed. put on a secondhand one. that failed in 2 weeks. i bought a starter from ebay ( 12mths warranty) and it seemed ok.
about a month or so ago when the first cold weather hit us, i realised it was turning over real slow and if too cold just not turning over.
replaced battery... still the same
had it to an auto electrician.. diagnosis timing belt slipped a tooth causing tight engine or starter faulty
replaced timing belt.... still the same
starter sourced secondhand from james on here
result.... now spins over like a sewing machine and starts instantly.
moral of the story.... dont buy cheap parts. they are cheap for a reason.
the starter is still under warranty so it will be going back to whence it came.
11 years 10 months ago #135140
by kirkynut
Replied by kirkynut on topic starting issues and the cure
Absolutely! There's a large amount of poor quality parts out there now. A large well known car parts chain sells alot of it, forcing small motor factors to reduce their prices to compete and in doing so they stock crap too.
Get to know a good motor factor and you should be ok.
Reconditioned is also better than the cheap new items.
Time to create page: 0.069 seconds
