Pulling to one side help!
- logun94
14 Jan 2015 00:27 #135065
by logun94
Replied by logun94 on topic Pulling to one side help!
i will check the calliper in the morning could do with the brakes bleeding while I'm on :pinch: thanks for the input much appreciated!
14 Jan 2015 14:14 #135074
by kirkynut
Why do you think you need to bleed the brakes? If you have a long pedal you've probably worn out your brake shoes at the back as mud gets caught in the drums and acts like grinding paste on them.
Replied by kirkynut on topic Pulling to one side help!
logun94 wrote: i will check the calliper in the morning could do with the brakes bleeding while I'm on :pinch: thanks for the input much appreciated!
14 Jan 2015 14:31 #135077
Replied by mlines on topic Pulling to one side help!
Long brake pedal travel could also support the stuck caliper theory.
14 Jan 2015 17:43 #135088
by Busta
Replied by Busta on topic Pulling to one side help!
I agree with the others- seized caliper. I spent a long time trying to bleed the brakes on a Jimny with rubbish brakes, then decided it must be the master cylinder so replaced that and still couldn't get a firm pedal or any braking. Turned out to be a seized caliper...
Time to create page: 0.094 seconds
