Rear axle Swap
- mickt
12 Jan 2015 19:56 #134911
by mickt
Rear axle Swap was created by mickt
I am having to replace the rear axle casing on my "new" 2001 soft top Jimny due casing has a cracked weld leaking oil. I have the disc that covers most of the vehicle but does not show anything of the actual axle/s and their contents( half shafts etc,) apart from a section on the diff itself. Before I start removing and stripping the injured party I would like to have all the parts needed to carry out the swap of bits. Has/does anybody have exploded views showing whats what of the offending beast, or at least point me in the right direction before I skuttle of to the dealer cap in hand?
- Gjmcleod
12 Jan 2015 21:15 - 19 Jan 2015 17:48 #134937
by Gjmcleod
Replied by Gjmcleod on topic Rear axle Swap
When I done my rear axle , I got most /all the parts , bearings , sealer etc right here from the big Jimny shop
Last edit: 19 Jan 2015 17:48 by Gjmcleod.
- gus2000
13 Jan 2015 01:59 #134959
by gus2000
Replied by gus2000 on topic Rear axle Swap
- mickt
13 Jan 2015 11:23 #134978
by mickt
Replied by mickt on topic Rear axle Swap
I must say your idea of "easy" means that I would love to see what you consider as a "hard" repair Gustavo!
I have looked in the shop and cannot see any reference to the rear axle as regards gaskets and seals Gjmcleod. It mentions the bearings, but as they seem to be serviceable I do not expect to have to replace them. I was hoping it was going to be a straight swap from one casing to another.
- mickt
13 Jan 2015 12:12 #134983
by mickt
j99pre;James so there are no gaskets for the diff to casing then and the hubs to axle casing.
- mickt
13 Jan 2015 12:17 #134985
by mickt
I take it the copper based sealant recommended for the king pin replacement would be ok then?
