Lift kit questions
  • mik641
09 Jan 2015 19:59 #134696 by mik641
Lift kit questions was created by mik641
Guys
looking at a lift kit which is 40mm, but they come with different options.
1, with the springs and shocks
2, above plus castor correction bushes
3, all above but includes full suspension bush kit.
now when doing the 40mm lift is it critical to have the castor correction bushes?
also after fitting does the car need to have a new wheel alignment?
thanks!
  • TomDK
09 Jan 2015 20:21 #134699 by TomDK
Replied by TomDK on topic Lift kit questions
C/C bushes are not critical, but a good idea to have :)
10 Jan 2015 09:23 #134716 by robs5230
Replied by robs5230 on topic Lift kit questions
thanks!
when the jimny is lifted, you are essentially moving the body/chassis away from the axles. the panhard rods connect the body/chassis to the axles and on a standard jimny are fixed length. when you lift, the axle will be pulled over to one side and the wheels will stick out further on one side to the other of the vehicle. you will have to check how much off centre your axle is and whether you can live with it. an adjustable panhard rod will cure this. i personally would cure this issue before castor correction on the lift you are proposing.
standard jimny - for now
Time to create page: 0.088 seconds
