Brake Fluid Change
  • gary410
11 years 10 months ago #134521 by gary410
Brake Fluid Change was created by gary410
What is the best wheel sequence for bleeding ?
11 years 10 months ago #134607 by facade
Replied by facade on topic Brake Fluid Change
Depends on why you are bleeding them ;)
If you changed a pipe, or a cylinder, start with the nipple nearest to it as that way you get rid of most of the air straight away.
If you are flushing the brake fluid, and there is no air in the lines, it really doesn't matter.
If you want to follow a sequence, it is usual to start as far away from the master cylinder as possible, so that would be:
OS rear
Load compensator above axle
NS front
OS front.
  • gary410
11 years 10 months ago #134718 by gary410
Replied by gary410 on topic Brake Fluid Change
Thanks facade it just a fluid change ;)
11 years 10 months ago - 11 years 10 months ago #134723 by facade
Sorry, I forgot the thread title within seconds :blush:
Use a syringe type thing to suck out as much fluid from the master cylinder as you can before you start, (obviously top it up again with new fluid :laugh: ) that way when the fluid looks clean you know that it is fresh.
Last edit: 11 years 10 months ago by facade.
