Rear bumper light/removal
  • tim_jimny53
08 Jan 2015 10:43 #134514 by tim_jimny53
Rear bumper light/removal was created by tim_jimny53
Hi all , I'm planning to remove the rear bumper off my Jim , looking for advise on how to move indicator's etc into the higher up light clusters , cheers tim
08 Jan 2015 16:32 - 08 Jan 2015 16:35 #134546 by robs5230
Replied by robs5230 on topic Rear bumper light/removal
i considered this and changed my mind. a few on here have done it. "mysticrich" for one. i bought spare rear light units and additional bulbholders for the job. in principle its easy enough. the reverse "clear" lenses are used for indicators with orange bulbs , the single fog lens is used for stop and tail ( the blank fog at the other side is the tricky bit as you have to dremmel it to take a bulb holder for stop and tail. you then need to relocate your fogs. the option that i would have chosen was on the rear door.
the stop/tail/indicator wiring is easy to get to and the fog is up to you. hope this helps and if you need any spare upper rear light clusters i have some. rob
standard jimny - for now
Last edit: 08 Jan 2015 16:35 by robs5230.
  • tim_jimny53
22 Jan 2015 20:42 #135764 by tim_jimny53
Replied by tim_jimny53 on topic Rear bumper light/removal
Thanks for the advise but I too have decided to keep the original bumper n lights , it's been cut down and looks good as it is B)
Time to create page: 0.072 seconds
