coolant spec for g13bb engine
01 Jan 2015 12:16 - 01 Jan 2015 12:25 #133788 by robs5230
can anyone confirm the antifreeze type / spec for the g13bb engine ? cheers
i'm going to do a full coolant change just to be nice to it and also wondered whether there was a specific method to drain / bleed / refill thanks
standard jimny - for now
Last edit: 01 Jan 2015 12:25 by robs5230.
  • jim
01 Jan 2015 12:48 #133793 by jim
Replied by jim on topic coolant spec for g13bb engine
I think the pink coolant is probably best I think it's good for 5 years it clams. The blue coolant was for older engines but you can still use it.
I haven't done a coolant flush on a jimny but on other cars I have removed the lowest radiator hose and drained it being careful not to spill any as its toxic.
I connect the hose and fill it up with clean water, let it run until it's up to operating temperature and drain it again. Sometimes I have had to do this a few times to get the water clearer. I also put the heater on so the water gets around the heater matrix to flush through. (This made my blower kick out more heat)
Once I have put the required coolant in I leave the reservoir bottle cap open to allow air to escape once it's back up to temperature close the cap drive it then check for any leaks.
01 Jan 2015 12:56 #133794 by robs5230
thanks.. i did wonder whether there were any bleed screws lurking around.
  • Olucas91
01 Jan 2015 13:04 - 01 Jan 2015 23:06 #133796 by Olucas91
Replied by Olucas91 on topic coolant spec for g13bb engine
As you look at the radiator there is a bleed screw at the bottom right of the radiator at the back.
That's a drain plug, not a bleed screw.
Just put the heater on hot and fill it up slowly, squeezing top and bottom radiator hoses gently to squeeze air out. Run the engine with the radiator cap off and refill as air comes out but put it back on before it gets too hot.
Make sure the expansion tank has enough coolant in it and keep an eye on its level and the temperature for a bit till you are happy it's settled.
Mine has never caused an issue.
Last edit: 01 Jan 2015 23:06 by kirkynut.
Time to create page: 0.078 seconds
