cv joint&4wd
- garrygun
when jimnys in 4wd high or low when i reversed around corner either lock it sounds like a cv tightening up jerking stopping quickly, i removed and greased the cv's put it up on stands and tried on full locks forward&reverse twas ok but not when on road, ive not noticed this before as i only use 4wd in slippy conditions.
am i doing somthing wrong or is this a jimny thing?
Thanks Garry.
- Biasmechanic
- garrygun
Biasmechanic wrote: The jimny doesn't have a centre diff so the only way to relieve the drive train wind up is by slipping a wheel. 4wd should only be used on surfaces where you will slip a wheel Eg mud sand snow. On the road is a big no no unless it's very icy or covered in snow. I generally only go into 4wd when I'm really struggling in 2wd or I need low range and that's off road, I've never used it on road unlike the previous owner who did and caused the transfer box mount to break due to wind up although it usually breaks cvs first.
thanks for answering my question guys,
iwas using it on slippy roads this morn, obviously wasnt slipery enough when i reversed on hard lock. (doh)
