New spotlight switching oddity
  • Mattzuki
29 Dec 2014 17:52 #133547 by Mattzuki
New spotlight switching oddity was created by Mattzuki
Hi All,
I wonder if anyone can help - I've tried the 'Search' facility with no joy...
I fitted a pair of spotlights today wired to come on with main beam and isolated via a switch on the dash. I followed the diagrams (for Suzuki's, negative earthed) and all works as it should, but...when I turn the headlights off and/or ignition off I can then turn the spotlights on with the dash switch. What have I done wrong?
Two uncertainties:
1. I took power for the dash switch from the one cable under the steering column I could find with 12v when the high beam was on - red with white stripe.
2. The switch I used is a Suzuki fog light switch which has five cables out of it. I assumed the two blacks were earth so used 1 of those. I checked continuity to find two others which worked when the switch is pressed on/off - a red cable for connection from the main beam cable and a purple one for the connection to the relay.
Should I have used a simpler 3-pin switch instead of the Suzuki unit?
OK, it all works as it should with the lights, but knowing my luck I'll leave the switch 'on' on a sunny day, leave the car and drain the battery.
I'll get the car cleaned up and post a few picks - bumper mounted spots, 1" lift at rear and off-set wheels. Looks good (in my eyes).
Anyway - any help would be most appreciated.
Many thanks,
Matt
  • mickt
29 Dec 2014 19:19 #133554 by mickt
Replied by mickt on topic New spotlight switching oddity
I think it is because apparently the cars are wired negative switching. So the feed is always there and the on/off is controlled on the return side, not the feed.
  • Mattzuki
29 Dec 2014 19:26 #133555 by Mattzuki
Replied by Mattzuki on topic New spotlight switching oddity
Thank you Mick,
Any idea how I should re-wire the switch? Do I swap over the cables from high beam and relay feed or do I have to move the Earth cable as well?
Cheers,
Matt
29 Dec 2014 22:22 - 29 Dec 2014 22:29 #133564 by mlines
As stated, Jimnys are negatively switched i.e all main electrical items (bulbs etc.) have a continuous positive feed and to turn them on then a negative (ground) is applied to the other side of the item.
Therefore your spotlamp relay/switch needs to do the same. You need to apply a continuous positive to the lamps/relay and on the negative side apply a ground (ie. use the ground that is also applied to the main beam)
Red/White appears to be the DIP beam which would explain why it goes to +12v when you switch to main as it goes into the 12volt float condition.
Main beam is the solid red and you should see this as +12v when main beam is off dropping to Ovolts when main beam selected.
You colour codes may be different as the model year changes.
Last edit: 29 Dec 2014 22:29 by mlines.
  • Mattzuki
29 Dec 2014 23:33 #133577 by Mattzuki
Hi Martin,
Many thanks. I'll try this in the morning. My Jimny is on an 03 plate by the way.
Best regards,
Matt
  • Mattzuki
30 Dec 2014 10:27 #133606 by Mattzuki
Interesting...I put the multimeter on both cables (the solid red and the red/white) with ignition off/key out and they both show 12v - which makes sense to me if that's why you can leave your lights on (but get the alarm sound with ignition off). And it would make sense to me why the spot light switch is then getting feed with the lights off/ignition off.
Is the solution then to put in a relay between main cable and the dash switch which takes its feed from something on the ignition side? If yes, what should I use?
Or is there an easier way of doing it?
Many thanks,
Matt
Time to create page: 0.274 seconds
