rear shock bushes
  • pcrepairmandan
29 Dec 2014 13:16 - 29 Dec 2014 19:12 #133517 by pcrepairmandan
rear shock bushes was created by pcrepairmandan
ive got pro comps on and the rear shocks, the bushes are worn out ,allowing the shock to rattle side to side
any idea where to buy the replacement bush? asap really
Last edit: 29 Dec 2014 19:12 by mlines.
29 Dec 2014 16:40 - 29 Dec 2014 16:42 #133537 by kirkynut
Replied by kirkynut on topic rear shock bushes
You wish is my command:
You have choices Sir:
www.bits4vits.co.uk/store/vitara-/-x90/r...ushes/prod_1154.html
or
www.jimnybits.co.uk/shop/jimny/service-i...ck-bush/prod_43.html
You pays your money, you makes your choice, but both are good companies and both will get them to you asap. Similarly priced, sold singly at Jimny Bits and as a pair from Bits4Vits.
I suggest buying a pair as if one has gone (and the Pro - Comp bushes do seem to go) the other side is unlikely to be far behind!
Last edit: 29 Dec 2014 16:42 by kirkynut.
  • Jimny-Dave
29 Dec 2014 17:38 #133545 by Jimny-Dave
Replied by Jimny-Dave on topic rear shock bushes
Thanks KirkyNut... B)
I'm in the process of having new moulds made for the top mount bushes as most bushes need cutting to fit the Jimny :(
New moulds will fix that though ;)
Dave
Time to create page: 0.080 seconds
