Master cylinder bleeding
- miktt100
24 Dec 2014 18:05 #133249
by miktt100
Master cylinder bleeding was created by miktt100
Master cylinder has been stripped now so I suppose I've got to bench bleed the master has anyone got any idea where I would get a kit or what size are the 4 outlets so I can buy some barbed screw ins and some tube . Has any one done this ? Does it need doing or should I just bleed through the system as normal .
The reason I ask is after I put it all back together I put a small amount of fluid back in master on my bench then pumped the piston a few times and not a great deal came out , and only from the back 2 , not a drop from front 2 and only a few bubbles popped back up in main reservoir from front feed ?
Any ideas ?
Any ideas ?
25 Dec 2014 00:12 #133264
by kirkynut
Replied by kirkynut on topic Master cylinder bleeding
I would fill the reservoir and open the bleed nipple on the rear passenger cylinder, being the furthest from the reservoir. Once fluid runs out get an assistant to pump the pedal while you open and close the bleed nipple and check the reservoir level. Once all the air is out do the nearside front and then off side front.
25 Dec 2014 09:40 #133275
by facade
Replied by facade on topic Master cylinder bleeding
Don't forget the nipple on top of the compensator valve above the rear axle. :ohmy:
It bleeds the front brakes.
- miktt100
25 Dec 2014 10:56 #133280
by miktt100
Happy Christmas all !!!!
Yeah that's where all this problem arises , I've had that off and cleaned it through , but when I bled it nowt comes out that nipple but if I take a feed to it off I got fluid from that ??
So I stripped master ,cleaned it now if I set it on my bench and fill it with fluid nowt comes out the front 2 holes and after consulting the God that is YouTube
it says you need to bleed the master by putting hoses coming from all your feeds into the resivoir which I can understand , but what size is the input size to the master ? Is it metric ? M12
Or is all that unessary? Bloody YouTube
Thanks once again , I'll go and enjoy Christmas now
Replied by miktt100 on topic Master cylinder bleeding
facade wrote: Don't forget the nipple on top of the compensator valve above the rear axle. :ohmy:
- GuardianAngel
25 Dec 2014 13:23 #133287
by GuardianAngel
Replied by GuardianAngel on topic Re:Master cylinder bleeding
I have spare unions at home, if you can get some off cut brake pipe we can make up a bleed kit.miktt100 wrote:
So I stripped master ,cleaned it now if I set it on my bench and fill it with fluid nowt comes out the front 2 holes and after consulting the God that is YouTubeit says you need to bleed the master by putting hoses coming from all your feeds into the resivoir which I can understand , but what size is the input size to the master ? Is it metric ? M12
- miktt100
25 Dec 2014 13:31 #133288
by miktt100
Oh cheers justin, happy christmas mate and I'll bell you this weekend
Have a good day
Have a good day
Time to create page: 0.107 seconds
