slipped timing belt ??
- Thank you received: 77
the symptoms i've had recently other than slow turning over are..
erratic idle ( not too bad at the minute)
increase in fuel consumption
puff of smoke on start up
any thoughts ??
it is booked in for a belt kit fitting on monday. its a 99 hardtop and has done 78k miles. i have mislaid the service book and cant remember when and if the belt has been replaced previously.
cheers
standard jimny - for now
all connections and earths been checked out this morning. invoice says slipped timing belt or faulty starter. 1st stop is the belt next mondayRhinoman wrote: Assuming the battery is good then I would start by checking the earths between the block and the battery. A slipped timing belt would show up with a compression test, if it spins fast enough with the plugs out, usually it would retard the timing which would lower compression and allow it to spin faster.
- Butta
i tend to think you're right. but the belt will be done then the starter.Butta wrote: Hmm not seen on a jimny but every time I have seen a slipped belt it has either run dog rough, had no power or smashed up the valves so im thinking that its probably not the belt however if you have no evidence its been done before then its a good idea to change it anyway
- Johnniehec
- Thank you received: 56
Be thankful it's not a 1.4 or 1.6 FSI VW their timing CHAIN can slip if you let it roll back in gear! It's happened to my Dads Tiguan twice!
