starter motor issues advice needed.
11 years 10 months ago - 11 years 10 months ago #133104 by robs5230
i seem to have been plagued with starter motor issues this year. the original starter failed about 10 months ago and i fitted a second hand starter that only lasted 2 weeks.
new starter fitted and happy days. no issues until about a month ago i noticed it was turning over slower particularly when the weather was cold.
bought new battery still the same. it has been starting but i've been dreading cold weather so this morning saw it at the auto electricians for a look over.
results ........
all contacts good.
no voltage drop.
diagnosis....
tight engine ( timing out ? )
dodgy starter ( the starter is drawing 240 amps to start the jimny)
any ideas or recommendations ?????????
can the timing slip and the car still run ok ????
the starter was a new item bought from ebay. is it possible is knackered electrically ?? are the starters for the g13 and m13a any different ? i did order the right one.
the car runs spot on though it did have a blip after changing the battery where the idle was iffy for a day or 2. running well at the minute and not short on power.
thanks in advance as its now doing my head in
standard jimny - for now
Last edit: 11 years 10 months ago by robs5230.
11 years 10 months ago #133108 by robs5230
bit the bullet and booked in for a cam belt and roller kit fitting next monday. not do it any harm, will it ?
11 years 10 months ago #133121 by facade
A belt change won't hurt.
Most likely the eBay starter has failed already. (Those Chinese children don't do a very good job for their 15p a day)
11 years 10 months ago #133128 by robs5230
facade wrote: A belt change won't hurt.
yep i'm inclined to agree with you. i'll try to source a reputable brand starter
Time to create page: 0.082 seconds
