Bigger generator
  • Pirate4x4
11 years 10 months ago - 11 years 10 months ago #133103 by Pirate4x4
Bigger generator was created by Pirate4x4
Is there any bolt on bigger generators out there or do I have to built new fastening points!!
I need at least 100Ah... but bigger is better!
Last edit: 11 years 10 months ago by Pirate4x4.
11 years 10 months ago - 11 years 10 months ago #133106 by facade
Replied by facade on topic Bigger generator
My alternator seized up a couple of weeks ago, and the brand new replacement is labelled 12V 85Amp.
Whether this is exactly the same as the original, which suzuki claim is "nominal 60A @ 13.5V" I wouldn't like to say.
Certainly it looks exactly the same, but new cars need more current for the power steering etc. so maybe it is uprated.
The point of my rambling is, 85A is not a million miles away from 100A, and it is an original fit, with nothing to alter.
However, from memory, the rear mount on the engine can be adjusted backwards to accommodate a longer alternator mounting lug, if a higher output alternator with the same method of fixing is available.
Last edit: 11 years 10 months ago by facade.
  • TomDK
11 years 10 months ago #133152 by TomDK
Replied by TomDK on topic Bigger generator
Pirate4x4 wrote: Is there any bolt on bigger generators out there or do I have to built new fastening points!!
Why not instead fit an additional Jimny alternator. If you Jimny is without AC there plenty of space to install if on the left side of the engine. This also gives some redundancy should one of the alternators fail. And easy to get new parts as both are original Jimny alternators.
  • Yellostreak
11 years 10 months ago #133164 by Yellostreak
Replied by Yellostreak on topic Bigger generator
be nice if someone made a kit for this..
11 years 10 months ago #133173 by Mescort
Replied by Mescort on topic Bigger generator
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Rockwatt crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
  • Butta
11 years 10 months ago #133176 by Butta
Replied by Butta on topic Bigger generator
Mescort wrote: here you go :)
1240.00 euros ha ha ha ha ha ha thanks for the laugh!
Time to create page: 0.119 seconds
