misfire
- crowe1281
11 years 10 months ago #132944
by crowe1281
misfire was created by crowe1281
Hi I am new to this my 55 reg jimny vvt is misfiring not all the time it does it when keeping at a steady speed our when working hard like going up a hill it does not put on the engine light and I have hand it read and there are no codes can someone help thank you.
Chris
Chris
- mickt
11 years 10 months ago #132945
by mickt
Replied by mickt on topic misfire
Could be a plug going down under load. Try taking them out and check if one is "wetter" than the others.
11 years 10 months ago #132954
by kirkynut
Coil pack on it's way out.
A code reader may tell you which cylinder, otherwise get a new one as I think they're the same for all cylinders.
It could be a spark plug though as said above, so whip them out and check them first.
- crowe1281
11 years 10 months ago - 11 years 10 months ago #132960
by crowe1281
Replied by crowe1281 on topic misfire
thank you I will take the plugs out tomorrow and have a look. One more thing it does some times when you pull up to a junction it has a bad idle you would think it was going to cut out then it sorts it self out do you think could be related to the misfire.
Last edit: 11 years 10 months ago by crowe1281. Reason: spelling
- mickt
11 years 10 months ago #132964
by mickt
Yes, plug or lead hot culprit. Just noticed that coil packs are not cheap , at least for the m13 anyway.
- crowe1281
11 years 10 months ago #133223
by crowe1281
Hi took the spark plugs out to day 2 and 3 where ok but 1 and 4 had been melted at the tip so I am thinking its the coil park. Can this do this to the spark plugs if one goes bad?
