Jimny radius arm guards fitting?
- Tomhorntoad
11 years 10 months ago #132909
by Tomhorntoad
Jimny radius arm guards fitting? was created by Tomhorntoad
Just bought a set with no fitting instructions
Ill be honest I havnt looked at them yet but I wondered if its an easy fit? Does it need a ramp? Etc
Kind regards
Kind regards
- GuardianAngel
11 years 10 months ago #132991
by GuardianAngel
No, just unbolt the radius arm bolts, fit the guards and bolt back up. The guards will probably come with new bolts which are a bit longer.
You might find that the original bolts have seized against the collars in the bushes. If so, then you wont be able to undo the bolt, so you will need to cut through the bolt. This is fine, but then it might need a new bush fitted to the arm if you cant get it out. I know this from past experience
When you fit the new bolts put a bit of copper ease on them to ensure they don't seize in the bushes in the future.
Replied by GuardianAngel on topic Jimny radius arm guards fitting?
Tomhorntoad wrote: Just bought a set with no fitting instructions
Kind regards
- Jimny-Dave
11 years 10 months ago #132992
by Jimny-Dave
Replied by Jimny-Dave on topic Jimny radius arm guards fitting?
Indeed, fitted my (ORA) ones quite easily -
The only thing that's slighlty awkward is getting the spacers between the guard and the original radius arm mount -
Shown at the top of the ORA fixings pack in the above photo...
But with patience it's easy enough to get them in and the bolts through the whole assembly...
- Jimny-Dave
11 years 10 months ago #132993
by Jimny-Dave
I bought up the remaining stock of ORA ones by the way, if anyone is interested in a set
:whistle:
www.bits4vits.co.uk/store/jimny/radius-a...moury/prod_1137.html
Dave
Dave
Time to create page: 0.082 seconds
