Worth upgrading brake pads
  • horam_jimny
19 Dec 2014 16:30 #132793 by horam_jimny
Worth upgrading brake pads was created by horam_jimny
My Jimny is due a replacement of the front brake pads, is it worth upgrading them above standard OEM parts?
I do a 25mile round trip commute in the Jimny on AT tyres and use it mainly for shooting so nothing extreme off road but would it benefit from better more aggressive/grippy pads for general stopping power? Or will the difference be so slight that for Jimny speeds etc its not worth the extra pounds?
19 Dec 2014 16:37 #132795 by Busta
Replied by Busta on topic Worth upgrading brake pads
Do you struggle to stop quick enough with standard pads? Or ever find that they fade from heavy braking?
  • horam_jimny
19 Dec 2014 16:41 #132796 by horam_jimny
Replied by horam_jimny on topic Worth upgrading brake pads
No I find it fine, the Mrs says it doesn't stop as well as her focus but then its a whole different car so Id expect it to behave differently.
The price for EBCs for example aren't massively more than decent standard ones so just want any feedback if they are worth the bit extra?
  • jim
19 Dec 2014 16:42 - 19 Dec 2014 16:48 #132797 by jim
Replied by jim on topic Worth upgrading brake pads
My experience of updated pads were for fast road or trackdays where having uprated pads would still perform well with increased heat and friction others preferred oem as they were cheaper to just replace.
I imagine our Jim's probably don't generate enough heat(not driving a hot hatch and using the low ratio gear for downhill)
I would look at replacing any worn parts with original quality, checking brake shoes and rear cylinders and making sure there's no brake fluid leaks. Check calipers they often need regreasing.
There's also a member on here that is selling rear brake drums to disc conversion if you want more efficiency.
James
Last edit: 19 Dec 2014 16:48 by jim.
  • jim
19 Dec 2014 16:49 #132798 by jim
I don't think you'd find much difference with ebc over original although they are meant to give off less dust keeping your wheels cleaner.
horam_jimny wrote: No I find it fine, the Mrs says it doesn't stop as well as her focus but then its a whole different car so Id expect it to behave differently.
19 Dec 2014 17:02 #132800 by Busta
A Focus will have more assistance from the servo, so the brakes will feel stronger when you press the pedal. This doesn't mean they are better brakes though. I always fit the cheapest brake pads my local factors supply, even on my track car, and I've never felt they were inadequate!
Time to create page: 0.096 seconds
