Tyres - online supplier WARNING
- Thank you received: 360
13 Dec 2014 15:57 - 13 Dec 2014 15:59 #132248
by Halford
Tyres - online supplier WARNING was created by Halford
not a happy bunny ... but thought I'd share as a warning to others ....
went to a local garage on Friday to have my two new Grabber ATs fitted ..... but it didn't happen.
Blackcircles sent x2 squashed sidewall tyres to the garage, not sure if the pics show a true perspective, but the gap between sidewalls was only 75mm
whilst, it wouldn't have been impossible to fit the tyres, using a technique employing bike inner tube inflated on one side thus enabling the tyre to be inflated, the garage (a premier fitting partner indeed) apparently weren't being paid enough to spend the additional amount of time on the job. After spending 60 mins in the freezing cold, Blackcircles eventually rang back and said a garage on th other side of the river (through a toll tunnel) at rush hour would be able to help .... errr I don't think so
so far ... I've been reimbursed for the tyres, but not for time and inconvenience and still don't have any tyres ... discussion is still ongoing as they apparently want to keep customers happy.
will post a further update with developments as they occur.
Last edit: 13 Dec 2014 15:59 by Halford.
13 Dec 2014 16:20 #132250
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Tyres - online supplier WARNING
Most tyre places should be able to fit those. Just need a cheater to put a good blast of air in there.
The following user(s) said Thank You: Halford
13 Dec 2014 16:30 #132251
by Halford
tried one several times, no good
Replied by Halford on topic Tyres - online supplier WARNING
Jezz wrote: Most tyre places should be able to fit those. Just need a cheater to put a good blast of air in there.
- Thank you received: 706
13 Dec 2014 16:51 #132253
Replied by jackonlyjack on topic Tyres - online supplier WARNING
just need to wrap rope/chain around the centre
and twist it like turn-akin add a good blast of air it will pop on
13 Dec 2014 16:56 #132254
by Halford
clever, that sounds like a plan, shame the garage weren't obliging
jackonlyjack wrote: just need to wrap rope/chain around the centre
- jimothy
13 Dec 2014 17:07 #132256
by jimothy
Replied by jimothy on topic Tyres - online supplier WARNING
I always use a ratchet strap if the Cheeter does not work.
Time to create page: 0.104 seconds
